Hey all. Subject says most of it. I've discovered something rather, well. Okay, fine, if I'm right, we're talking at least half a dozen Federal statutes and that's without actually searching.
I'm specifically looking for folks with resold ADSL/ADSL+ in the Midwest region (OH/MI/IL/IA) who are seeing strange or inconsistent problems specifically with BitTorrent traffic, or simply what seems to be hard caps at or around 30K/s, or any number. This would be most helpful if you also have a work VPN you can access, and can get your network administrator to let you perform testing with a legitimate Torrent for several minutes.
The observed behavior here has been that BitTorrent traffic, both encrypted and unencrypted, is being capped at 30K/sec download. Can't test upload due to a line problem they still refuse to even investigate. Same torrent, same peers, inside a VPN connection would max out the line within 30 seconds. (Insurgency mod for HL2.) I've confirmed verbally and visually with my ISP that no QoS is configured at the routers, and their lone PacketShaper was moved to a remote location. (If traffic was passing through it, my speeds would be worse than dialup for everything.)
Comcast part deux? Boy, don't we all wish - this is worse. This is occuring on resold DSL lines. This is where AT&T bundles various DSL circuits into a single ATM transport up to the ISP, who actually carries all the IP traffic. Which is why I'm looking for other folks who are seeing the same behavior. I have a suspicion as to what exactly is going on, but would like to get confirmation from others before taking a metal bat to AT&T's face over the repeated denials.
