Looking for an ITX case
janas19
I need a case for a picoPSU and low profile GPU, nothing else. A slim media bay which sits directly above the mono would be nice but not mandatory. I've checked Newegg and found nothing. I wish Silverstone had such a case but they are all SFX except one. PicoPSU cases didn't have a low profile slot that I've found.
Any suggestions?
Hey Janas,
I am a Silverstone fan boy. They have great cases. I actually needed something similar for my home firewall / router project. I needed small ITX case, no PSU, and supports a low profile network card.
I actually got one of these: http://wesena.com/en/product_show.php?id=150 Its made out of aluminum like the SilverStone cases.
It even has room for a slot load optical, 2.5 and a 3.5. Just make sure to carefully measure the size requirements of the heatsink fan and Gpu. There isn't much free space.
- Ton
Dude, that FC7 is a pretty sweet case. Basically exactly what I was searching for, so thank you so much for that. Now... If only they only offered a cheaper steel version!
