looking for an ATX case
DirtyApe
im looking for a good quality ATX formfactor case that is around $150 and good for carrying to LAN parties and such so it cant be heavy.preferrably a midtower but im open to suggestions. i would like the case to have a window on the side and good for the gaming rig in my sig.easy installation of parts and i dont have a PSU already. thnx for any input :D
your journey begins and ends at the lian-li pc-65. either black or silver.
PSU not included.
way too plain...i was looking for one that is premodded cuz i dont have the time to do it myself. and i have little to no experience with modding. i did cut out a blowhole ontop my case with a dremel and put handles on the top also. but thats about all of done as far as modding goes.
Usually, unless you have a server case, cases are not what is heavy, the stuff inside is.
If you are looking for as light as possible, then you will want aluminum.
