Preface: In the thread title I've specified a floppy connector as being required. This is due to the fact that I want to install XP Pro x64 on a SATA boot drive. The only ways (AFAIK) to install without a floppy connector on the board are a USB floppy drive or slipstreaming the SATA drivers into the installation, neither of which I want to do. If there's an alternative way which doesn't require buying additional hardware or slipstreaming please let me know and that can drop the floppy requirement.
I'm looking for a new AM3 motherboard to replace my old M3A78-EM that's currently in my home server. As the title says, it needs to be mATX and (given the preface) have a floppy header.
The other components in the system:
Case: InWin Micro ATX EM002
PSU: OCZ ModXStream Pro 700w
CPU: AMD Phenom II X6 1090T BE
CPU Cooler: Coolermaster Hyper 212+
HDD: WD 2TB Caviar Green
GPU: Integrated
RAM: <See Below>
Optical Drive: SATA DVD-RW (dunno what model yet, doesn't really matter)
PCIe: RocketRAID 2314 (x4 slot)
PCIe: Intel Pro 1000/PT Desktop (x1 slot, unless the gigabit LAN on the board will provide similar/better performance)
I don't need USB3.0/SATA3, but I wouldn't mind paying a small premium to get them to give me a bit of headroom for the future.
I've been looking around for a while and found a couple of candidates:
GIGABYTE 880GMA-UD2H
ASRock 880GMH/USB3
It seems there are quite a few boards that would be candidates but they don't have floppy ports. For example, the ASUS M4A88TD-M and the MSI 890GXM-G65.
Another thing to consider is the RAM. I want to go for 4*4GB sticks, but one of my concerns is that due to the small form factor and the relatively large cooler it seems like I need to look hard for RAM that's not going to get in the way. This probably rules out stuff like Corsair Vengeance and G-Skill Ripjaws. This seems to force me into stuff like the slower 1333MHz CMX8GX3M2A1333C9 kit from Corsair. Is this accurate? Are there any good 8GB kits (2*4GB) that are fast and low profile? My searching on UK sites isn't turning up much atm.
It feels like the mATX route is quite constrained at the moment, but I really don't want to go down the ATX route for cost and space concerns. I'd appreciate any help or advice you could give on my mad ramblings. Thanks in advance.
GPU: Integrated
RAM: <See Below>
ASRock 880GMH/USB3
