ok im going to start ordering parts one by one hopefully it wont take 2 long. ive got it at a price i can pretty much afford. Im going to be using my own hard drives, Monitor and Drives.
COOLER MASTER HAF 932 RC-932-KKN1-GP Black Steel ATX Full Tower Computer Case - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160
EVGA 141-BL-E757-TR LGA 1366 Intel X58 ATX X58 SLI LE Intel Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188049
XFX GX275XAHFF GeForce GTX 275 896MB 448-bit DDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150387
CORSAIR CMPSU-850TX 850W ATX12V 2.2 / EPS12V 2.91 SLI Ready CrossFire Ready Active PFC Power Supply - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139009
Intel Core i7 920 Nehalem 2.66GHz LGA 1366 130W Quad-Core Processor Model BX80601920 - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
OCZ Gold 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Voltage Desktop Memory Model OCZ3G1600LV6GK - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227365
Total: Subtotal: $1,088.94
Which monitor/resolution are you using? Acer h233h 23 inch 1920x1080
What are you going to use this system for? Gaming only
Which hard drives are you reusing? 640GB sata HDD, 1 DVD RW, 1 Blu Raay
I know it's a matter of personal taste, but can you explain to us why you chose those particular parts?
Case: i just think it looks cool. Its either this or the antec 900
Mobo: I went with this because I liked the look of it and reviews. I can def do somethign else thats cheaper.
Video card: I went with this card because i read some Reviews between them all, 275, 285 and 295 and to be honest all but the 275 are out of my price range
PSU: i want a PSU that can handle basicly anything if i decide to upgrade in the future I dont want to go out and have to buy another PSU
CPU: all i can afford and alot of people told me to get it.
Memory: The memory was the cheapest i could find for the speeds that matched the board
CPU Cooler. is still a debate either i need it or not. I am not overclocking.
