Looking for advice on case fans
blairellis
Anyone got any recommendations for cheap QUIET fans that flow some good air? I need 3x120mm and 1x80mm.
My 120mm tT in the front of the case is probably the loudest fan I have in the whole case right now and its a little too loud for my tastes.
Google Yate Loon or Panaflo. They both make good fans that are pretty quiet for the amount of air they push. Thermaltake routinely rates their fans at much lower dBA and much higher CFM levels than you'll likely ever achieve.
Yate loons are about 3.50 and have a very nice dba/cfm ratio, with very impressive static pressure.
If you don't want sleeve bearing fans, check out the Scythe S-Flex or Panaflo Hydrowave bearing fans.
After just plugging in my first Yate Loon, I'm never buying anything else ever again. I could not hear it over my hard drive from 3 feet away. They may be cheap and sleeve bearing, but they are so quiet it boggles my mind.
I like my Silverstone FN121's, they are really quiet and blow decent air. Not the cheapest though at $9 a piece.
On a side note, I stole the 120mm Antec fan from my old Sonata case, and that thing blows some serious air and is still quiet! I was really surprised. I switched that with my Silvestone in the back and now have a Silverstone intake fan and 2 more in the case blowing over the ram/cpu and one over the video card. Dropped my 8800 temps by almost 10C!
Yate Loons are good, and this one: KINGWIN F-012BB 120mm, good reviews and $5 at Newegg
