Hi all,
I am hoping someone can give me some advice on the best way to enhance my audio setup.
Currently, I have an MSI K8T Neo2-FISR motherboard with Realtek AC'97 on-board audio. My case is an Antec SLK3700BQE which doesn't have any front audio jacks. I have JBL Creature II speakers, and a Logitech Precision Gaming headset/mic (which I think I'd like to replace since it isn't comfortable for me to wear).
I'm interested in getting an X-Fi card, but I have some concerns. I've been reading some of the posts here to try and learn more about it, and the part I'm especially concerned with is the whole "FlexiJack" thing. It sounds like you either have to use it for speakers or a mic, but you can't use both.
At this point, I'm thinking that the X-Fi Platinum makes the most sense, since I could use the X-Fi's audio jack for my Creature II speakers, and then the jacks on the front I/O port for a headset.... and this would be pretty nice, since again, my current case doesn't have its own front audio jacks. But I also don't know much about this, and wonder if there's a better way (i.e. with other cables, could I hook the Creature II speakers up using some other method). $200 does seem like a bit much to me to spend, but I get the impression that you get your money's worth.
Aside from that, if I get the X-Fi, is there a better audio connection to use to hook my speakers up to it, or would that only come into play with higher end speakers?
If anyone also has any good advice on a good headset that I could use (ideally I'd like something that had good audio quality so I could use the same headset just for audio even when I didn't need the mic), I'd also appreciate it.
The other option I was thinking of was to just buy the XtremeMusic, and get a USB headset, so if anyone has any good recommendations for doing that, please let me know.
Anyway, thanks for any advice you can offer!
Thanks,
Zadillo
Thanks,
Zadillo
