shadowsoal
- Dec 15, 2008
Hello everyone. I'm looking for advice on a system I'm building. It'll be the first time I'm building a computer in a long time and as far as I can tell nearly everything has changed, so if I've made any stupid component choices please tell me. My biggest concern is compatibility, I want to ensure the parts I've picked out will play nice with each other. I'm also looking to ensure I'm not going overkill or underkill on any of my components.
I plan to use this machine for some amount of gaming, a lot of text processing, web browsing and movie/television viewing. It will also probably be used as a test machine for high performance parallel applications (my research field).
My Budget is about $1500, that includes tax shipping, the works
3) Where do you live?
US
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
I'm building this machine from scratch, so I need everything that goes into a computer, CPU, RAM, mobo, PSU, GPU, Case, HD, optical drive, monitor (am I missing anything?)
As I said above, this machine is being build from scratch, I've only got a laptop presently so I won't be able to recycle any parts.
6) Will you be overclocking?
I will not be overclocking
7) What size monitor do you have or plan to have?
I am planning to get a 22" 1920x1200 monitor
Sometime between now and mid-January
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
I'll need RAID, and I doubt I would need Crossfire/SLI for the limited amount of gaming I do.
These are the components I've tentatively picked out, I'm looking for any sort of feedback, if anything seems overkill or underkill I'd love to know, if people have had good or bad personal experiences with any of the components I'd love to hear them.
Intel Core 2 Quad Q9550 Yorkfield 2.83GHz LGA 775 95W Quad-Core Processor Model BX80569Q9550
SAPPHIRE 100245L Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card
Western Digital Caviar Black WD1001FALS 1TB 7200 RPM SATA 3.0Gb/s Hard Drive (x2 for RAID 1)
GIGABYTE GA-EP45-UD3R LGA 775 Intel P45 ATX Intel Motherboard
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model F2-8500CL5D-4GBPK (x2 for a total or 8GB of RAM)
Thermaltake Purepower W0100RU 500W ATX 12V 2.0 Power Supply
COOLER MASTER Centurion 5 CAC-T05-UW Black Aluminum Bezel , SECC Chassis ATX Mid Tower Computer Case
SAMSUNG 22X DVD Burner Black SATA Model SH-S223F
Lenovo L222 HD LCD Monitor with Soundbar--4432HF1
All comments are very welcome, if any more information is needed I'll gladly supply it as soon as possible. I want to ensure that everything I've picked is a reasonable decision, and that all the components will be happy with each other.
Thanks in advance
**edit**
It's been suggested I consider an i7 instead of the Q9550, any thoughts on the tradeoff here? I'd either be dropping the clock rate from 2.83 to 2.66 for essentially the same price (saving like ~$20) or stepping it up to 2.93 for an extra ~$250. Considering my budget I'm not sure if the latter is worth it, and I'm unsure if I will get better performance from the former. My initial instinct was just to stick with the Q9550, but if I'm being naive I'd like to know.
US
Thanks in advance
**edit**
