I am trying to find a case that might fit my needs for video workstation duties, but there are so many options available that I might need some help from you.
My present case is an Antek P180, which is the first "lower" case I've had in a long time. It does have some practical solutions but others are not so much.
Things that I need:
1) Side inserting HDDs. This is something I had on my previous case and I do miss that very much. It's a LOT better than the usual insertion from behind/inside the case, which I don't know how is it called or described.
2) Plenty internal space and ventilation fans for cooling HDDs and mobo chipset. I can't understand why that is not taken care of in the Antek P180.
3) Reasonable price. That probably eliminates all aluminum cases and many fancy types.
It's quite likely I will have to go back to a taller and/or deeper case, like my previous Cooler Master case was. Unfortunately I can't remember the model it was.
Things that I need:
