Looking for a white case
Penguincomp
Racer [H]
Ok..I've been searching for hours now, have not found what I'm looking for and am hoping that someone can help. This is what I'm looking for:
White Case..Need a mini and mid tower. No other color
No Door
For one case, I need a window installed.
For the other case it must be a solid door as I'm going to cut out a design.
Blowhole is optional but desired
PSU is optional
Other options that can be considered is if I could buy an aftermarket door with a window already in it.
well, im actually here to help Penguincomp,
i feel that lian-li fits ur preferences nicely, look at the white pc61 (no window) and pc65(basically the same case with a window) both are around ~$100 if u want to spend $200 on cases, but its not that expensive and i suggest that if this is ur first mod to get a $30 case to practice....the only con to these cases that i see are that they only have 80mm fans....and do they even make cases with blowholes? i think ur gona have to buy a pre-mod or do it urself..no psu included
Ok smartasses...I searched Newegg, directon, xioxide and SVC before I even posted here. I had thought that most of the jackasses had left the forums by now. God forbid some of you post something constructive instead of the same bullshit over and over again. And btw...Newegg isn't the end all be all.
My thanks to Gamekid, Tiny and domoMKIV who were actually helpful. I thought I looked at those cases, but I'll look again as they may have been out of stock or my eyes were glazing over as I was searching.
allways here to help...
and what price range are u looking at? besides the cooling or price, the lian-li cases i mentioned sound good and if u need better cooling, i saw a guy mod 2 120mm fans inside where the 2 sets of 80mm fans were and got excelent temps.
and if u want practice modding, i saw a cheap $30 raidmax case on the egg a while back that is pretty plain ... but i dont suggest putting ur rig in it though lol
Found some more, but since I don't know your budget...it is a wide range.
In no particular order:
1. http://www.xpcgear.com/cdgn6097sil.html = not white, but I think it looks neat and has some great modding potential....I may pick one up myself.
2. http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=981468&CatId=1290 = yeah it is Tirgerdirect, but if you don't like them you might be able to find it else where, again I kind of like this one.
3. http://www.xpcgear.com/cp808pl1.html = I think I actually heard this one cry out, beggin' to be moded.
4. http://www.athenatech.us/a100ww.htm = mATX.
5. http://usa.aopen.com/products/housing/H420series.htm =mATX, pretty neat I thought.
These were just a few....if I come across any more than I will post them.
Good luck.
The Enermax case is perfect...Picked up a black one for a computer I'm building someone else to test it out. What I've noticed so far is that the metal on the backside is weak. Other than that..it's about perfect.
As for my case modding skills..I've been modding cases for the past 4 years..cutting out my own windows, blowholes, custom automotive finish paint jobs and the like. Modding a case to take 120mm fans is standard in most of my cases.
Here is a product link.
I think I may pick up the white one myself for my lady friends computer that she wants me to build her.
I saw that case today and hated it. The silver fan covers dent like mofo's and end up looking like crap. Check out the Enermax CS-125 Series. It's nice, clean and completely moddable. I have the black one here now. Making a system recovery disk atm. CS-125
