...an aluminum case
. actually guys, i'm gonna be doing some intricate work with my case (small cutouts) is it possible to score out the cuts using a small blade or something? the cuts will be small and straight but i don't think i can be steady enough for a dremel to go between the cuts. i used the term "score" because with acrylic you can basically draw lines in it til it splits, wondering if there's a technique out there for this. if anyone gets confused, i'll try to explain what i want to do more. thanks guys.
flip
flip
