looking for a water cooling starter kit
well i decided to buy a water cooling system for my P4
but i am having a trouble deciding wich one fs better :
- the koolance exos
- the evercool wc201
or the coolermaster aurogate
now i have heard about kits from companys like "danger den" but they look not so user frendly and quite frankly i am afaried they leak in the case.
if you know any other good kit that is better then the ones that i wrote above tell me .
btw i am looking to watercool my GPU to so keep in mind that ill need a GPU block to.
my cpu is a P4 2.6c
and my Graphic card is a R9600P by tyan
my mobo is an ABIT IC7-MAX3
and my budget is 200$
thanks in advance ;)
Yeah, the koolance Exos gets the nod. Not that the other choices suck at all. Its just that its reviews have all been excellent from website reviews to the customer reviews on Newegg.com ( 5 out of 5 stars), and Ive heard it can be modded out a fair bit if you want to mess with it down the road.
Also the exos comes in steel or, for a bit more money, aluminum. unless you need it to weigh less Id go steel. I read that with it sitting on top of the case the aluminum one is too easy to accidently nock off.
my personal opinion is a little more in this forums so you get a touch of things, and go for a diy kit, its cheaper, cools better.
