You can view more about the card here.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202005
I've been searching for awhile now but have not been successful finding a water block as I plan on water cooling my cards and going in with a 3 way crossfire for stability and awesomeness.
Is there instructions for removing the fans and heat-sinks? This would technically be my first time water cooling video cards no so much a system though.
I will be doing a 3 way crossfire config, I'm looking also at the MSI Lightning BE as well as it's the only water block I can find.
