Looking for a stable PSU
Black Label
Hi i'm looking to buy a psu for my system. im looking for something under $100. heres my system which it will be powering
asus p4p800-e deluxe, 20-pin
p4 2.8c @ 3.5
corsair vs @ 200mhz 2.5-3-3-8
lite on cd-rw/dvd-rom
hitachi deskstar 80g, 7200rpm, 8mb cache
asus 9800xt
sound blaster live 5.1
and 5 80mm fans in the case
something that is stable (my current generic psu undervolts and fluctuates)
something that has a standard 80mm fan that can be replaced with an led fan in the future
can anyone suggest a good psu for my system?
thanks in advance for replies
wow that looks like a great powersupply! only on problem with my case is that theres no gap above the psu so that fan on top would be cut of from any air. would that be a problem. seems like it would create a vaccum effect and the psu would get hot. also will all atx psu's fit in all atx cases?
the fan is on the bottom ;) so it would be just above your cpu say.
holy sh*t!!!! you responded to my post in like 3sec! i hit refresh and your post was there!
thanks man i think ill go with that one, the 92mm fan right below the cpu would be great in my system and that psu seemsvery stable
thanks for your help
do you know if the fans in there are standard and can easily be replaced? also will it fit in my codegen atx case?
