Looking for a slim lcd.
stooleywood
I'm looking for an LCD for my second desk, but i'm having trouble finding one that fits my requirements.
I would like something fairly slim/thin and has at least 2 hdmi ports. Since this monitor will be on an lcd mount, I would prefer if it was an IPS panel as well. 1080p minimum, and I think for this setup 24inches might be "too" large. Perfect size would be 20~22 inches..
No limit on the price. Thanks in advance.
I already have a 3008wfp, not looking to get something that large. However looks like that LG you listed comes in a 23inch version as well. However some of the quick reviews I've read say it isn't that good.
Why do you need two hdmi inputs? Unless there's audio out on the monitor, there isn't any downside from a simple hdmi -> dvi cable.
While you are correct, that's just how my current setup is. Laptop goes into my avermedia and outputs from the avermedia go to the second display. Second HDMI port goes to my gs3 when I use the mhl connector.
