Looking for a screensaver..
MJCfromCT
Howdy all,
I have a dual monitor setup, and I am looking for a particular screensaver for it. I have a folder with dual monitor images that I'd like to randomly be shown as the screensaver. You'd think the regulard Windows Picture Slideshow screensaver would be enough, but unfortunately it isn't...
The built-in windows one doesn't seem to want to span the dual monitor pictures across both monitors. Instead, it'll take the picture, and cram it onto just one of the monitors. I'm looking for something that'll span both monitors.
I came across the e-motional Images Screen Saver, which does everything I want, except it doesn't have that many options in terms of transition effects. I'd REALLY like a fade transition effect, but alas, this screen saver doesn't have one.
Any ideas, fellow [H]'ers?
Thanks, but this doesn't really do what I need it to do. It will display the images, yeah, but it won't span them over both monitors.
Have you looked at UltraMon? It has several utilites for multiple display screensavers.
Don't know if it will do exactly what you want, but it may be worth a look.
Yeah, I'm currently running ultramon for other things besides the screensaver functionality, AFAIK ultramon can't do this.
It seems like such a simple thing to do, there must be an easy way. :)
