I'm building another computer, and I'm sort of out of the loop I guess. Firstly, the motherboard I'll be usng accepts 24-pin, but I think 20-pin might be cheaper and then just buy an adapter for that. The hardware I'll be running is an AMD 64 3200+, Geforce 6600GT, MSI K8N Neo4 Platinum mobo, 2 WD 80GB SE HDDs, Sony Internal 16X DVD+/-RW drive, and a couple additional fans. It should be noted that I don't plan on overclocking at all for now. How much wattage should I get total, and what is a good cheap drive for my needs? I know Antec is reliable and trustworthy, but they're pretty expensive. Does anybody have any opinions on this Powman Demon 480W PSU? http://www.newegg.com/app/viewProductDesc.asp?description=17-163-017&depa=0
Also, I still need to find a case, I want one that is well made but nothing too extravagant/expensive/flashy. I want to make sure the PSU is secure in it most of all, and ease of installation is a plus I guess. I'm trying to spend like 80 combined on the case and PSU. Any suggestions would be great. Thanks.
