Looking for a recommendation on two builds
Incramus
Like the title says. Looking for something good, that runs quiet and under $75
Build one:
GIGABYTE GA-78LMT-S2P
Phenom II X4 965
HyperX blu 8GB DDR3-1333
DVD Burner
XFX 6850 (with two 6-pins)
WD blue 1TB HD
Build two: (guessing this PSU might run more than $75)
* = adds-ons from first build
*GIGABYTE GA-970A-UD3
Phenom II X4 965
DVD Burner
*XFX 6850 CROSS-FIRE (with two 6-pins ea)
WD blue 1TB HD
*SSD OCZ Agility 3 120GB
Thanks in advance!!!
1'st Rosewill Capstone 450W
2'nd Rosewill Capstone 550W
They're excellent units and best you can get with that budget.
If you're not in NA let us know where you'll be buying from(link/s to the shop/s in question).
Thanks!! I'll check out that Rosewill Capstone 450W. I usually shop Microcenter or New egg.
But on the 2nd build, it doesn't look like that PSU will have enough Connectors to run crossfire, won't I need 4 x 6-pin?
