looking for a receiver need help
VA Supremacy
Which one is better Sony STR-DN1000 or Pioneer VSX-1019AH-K or something else?
$500 is the most I will spend on one.
looking for one that handles either all or almost all DTS, Dolby etc formats
thanks for the help.
ryu4000
If you dont need 4 hdmi and upconvert to 1080p buy a vsx-919 over a 100 bucks cheaper
VA Supremacy
i'll look into it thanks
anybody else have opinions on which is better and cheaper than the Sony STR-DN1000 or Pioneer VSX-1019AH-K
Demon10000
Check the HotDeals forum to a link to the Onkyo 806. It's a solid receiver with quite a few higher end features.
Ryland
I just purchased a Yamaha RXV-565 but haven't had a chance to set it up yet. You can find the 465 for $280 if you look around and it is very similar.
VA Supremacy
ended up buying Pioneer VSX-1019AH-K since it was easier to find also got Polk RM6750 speaker set
though the speakers are ratedc 20-100 and the pioneer is rated 120. is there anyway to use the speakers? or do i have to buy a new set?
thanks
