Looking for a PSU. Need not be quiet.
young boy
I have heard about "Turobo-Cool Silencer 750 Quad (Crossfire Edition)" boasting about their 99 Active PFC, Rock-Solid Super-Clean DC Output (0.01 Load Regulation).
Is it that good? Any other recommendations? It runs on 110Volts AC input but my input is 230Volts. What do I do?
I'm looking for a 750watts PSU. Active PFC prefered and good DC outputs followed by energy efficiantcy
PC power&cooling 750w silencer quad is an excellent PS. What are your computer spec's btw, perhaps you could go with a lesser/less expensive PS like corsair hx520. Either is fine but its hard to recommend a PS without knowing what system/specs you are running.
I'm so sorry to have missed out that information!
CPU: E6850
GPU: GeForce GTX 8800 (500/450watts I think)
2 Raptor X.
9 X 29watt fans.
CPU: E6850
2 Raptor X.
9 X 29watt fans.
The GTX uses about 160-200W max, depending on if it's overclocked and such.
The E6850 could use around another 100-130W depending on overclocking.
Two hard drives are about 10W-15W each, even raptors.
29watt fans? Well, assuming that's right (2.4A each? which fans are these?) then that's ~270W from fans (which is more than I've ever heard of).
Doing the math there, you're somewhere between 550W and 630W at absolute max load with every core stressed, the system totally overclocked, etc.
But I don't know how there's any way those fans are really 29watts. Most fans are .5A-1A, not 2.4A. I'd like to see those fans!
A typical system like yours would be fine with a high quality 450-550W PSU.
Delta 220CFM 120mm X 120mm X 38mm fans for my CM 832 case.
I have a big problem. No matter how good a PSU is, I can't possibly run a 230V AC input on a 110V AC input PSU right??? So what do I do?
Almost all new PSUs are universal. The Corsair PSUs are full range from ~90V-~260V or so, and they auto switch to the right input voltage.
Thanks for the fan, I now see why you said noise was no concern! hahaha.
It makes me wonder why you chose to go with those fans. Most systems don't need any more than one 120mm intake and one 120mm exhaust at 1000RPM if even that.
