Looking for a pretty wide case
xDagger
Anyone know of a fairly wide case? I'm looking to do some modding in the near future, and some of the things i'm thinking about would require a case that's more than 9" wide. I've been looking at the stackers and the p180, and also a few Lian Li's, but nothing seems wide enough. thanks.
LiLi PC626.
It's not a cube, but it's 10" wide as I recall. Big does not begin to describe it. It's wide enough to put 5 x SCA 1" bays side by side.
Or...if you felt like modding, just get 2 cheap cases and put them together
I was thinking about doing that actually. Just some ideas i've been playing with. I'll toy around with autocad later see what I can do.
Thanks for the replies all
ghetto it. just get a cardboard box the right size and duct tape it up, cut holes for fans and connectors, spray paint it metallic black and put the components in. wow u just saved like $250 on a case
i think building a custom case would be a good idea for you. start with a lian li mobo tray and build the rest!
