Lol shouldnt say that liquid cooling can get very expensive. You thinking compression fittings or barb fittings? Are you going for looks or dont care how it looks?
Compression fittings look amazing but are very expensive
Barbs dont look as good but are a hell of a lot cheaper
tubing- 1/2" ID i think.
Are you looking to just cool your CPU? If so check out some Xspc rasa rs240 or rs360 kits. Great performance/price ratio...
I have an Coolermaster 932, Intel DX58SO, and i7-2600k. What would be an nice simple Watercooling? Open to suggestion!
sorry about that i was typing and talking about the i7-2600k. i ment to say i7-960
I would start off with a RX360 kit if you're doing CPU only. Be sure to add a silver killcoil or PT Nuke. Afterwards, you can change to compression fittings or whatever you want. You can add GPU's later also.
No budget limit?
My suggestions would be:
Koolance CPU-370 or the Cuplex Kyros Silver edition if you want to spend a lot of money (block is 92.5% silver, and honestly if I got this, I would put it on display rather than using it)
MCP655 with the bitspower sparkle custom dressing (makes it look really damn nice)
Feser UV reactive tubing, 1/2" ID with 3/4" OD, 7 to 8 feet should give you plenty of tubing
Bitspower compression fittings 1/2" ID 3/4" OD
UV Cold Cathode tubes with a sound sensitive inverter <--- I have this, makes things look really cool when you're playing music
Gentle Typhoons when they come back in stock, 1850 RPM models, 6 of them
A fan controller of your choosing.
Black Ice GTX 360 (fits natively in the 932)
Silver killcoil
A reservoir of your choosing, I like those FrozenQ T-virus ones
For GPU blocks, I would pick a fullcover one that you like aesthetically, just make sure it fits your GPU. At the moment I would avoid EK products though, they are having issues and poor customer support at the moment.
Corsair Hydro Series comes to mind when you need cheap + watercooling. But it won't be very good compared to something you build yourself. WCing is generally a very expensive hobby (when done right).
