looking for a nice mid-sized liquid cooling case
o0akoni0o
so what are some good liquid cooling cases out there that are relatively smaller than typical watercooling cases. looking for 17" tall or smaller, but it has to have adequate room for all my watercooling goodies as well as 120mm fans.
You might want to check out the Lian-Li PC-65, theres a version with 2 120MM fans instead of the 80mms that are uusually on the PC-6x cases. You can mount a 2x120MM radiator at the top of the case with a little modding, you can fit a resoviour in one of the 5 1/4" drive bays, and you can easily mount a pump in the hd cage.
those two cases mentioned are great, but they're too big. in fact i would love to get the aurora, but due to my tight living spaces at my dorm, 17" is the maximum height of a case so that it can fit on this lower shelf of my desk.
