Looking for a new case
Discussion in 'Cases & Case Modding' started by exiled350, Jun 3, 2018.
  1. exiled350
    exiled350 Gawd
    926
    Jun 26, 2013
    Since my current rig is due for a rebuild I'm looking to modernize as well. Currently rocking a switch 810 and honestly I'm over how big it is. I need room for a 360 rad on top, good front airflow and somewhere to mount a d5 with a medium size reservoir. Currently debating between coolermaster h500p white and inwin 303. Taking any suggestions for a large mid tower less than $150.
  2. DoubleTap
    DoubleTap [H]ard|Gawd
    2,017
    Dec 16, 2010
    Lots of new cases being announced at Computex this week...
  3. hititnquitit
    hititnquitit Limp Gawd
    331
    Apr 16, 2018
  4. exiled350
    exiled350 Gawd
    926
    Jun 26, 2013
    I've always wanted a Lian Li case but just can't justify the cost.
    Algrim likes this.
  5. Spartacus09
    Spartacus09 Gawd
    849
    Apr 21, 2018
  6. exiled350
    exiled350 Gawd
    926
    Jun 26, 2013
    Ended up going with the h500p mesh, thanks eBay 20% off coupon.
    HiryuuX likes this.
  7. Lumpus
    Lumpus Limp Gawd
    228
    Sep 2, 2005
    I love my Corsair Air 540... huge - easy to work in with old fat fingers. Drives air like a tornado with 2 - 140mm (or 3 - 120mm) fans in front. Corsair H115i 280mm radiator fit perfectly up on top with room for the water hoses.
    Just finished a new build in it... haven't cleaned up the cables yet
  8. exilelrrp
    exilelrrp Limp Gawd
    283
    Jun 11, 2010
    Damn! :eek: You got some spaghetti western cables going on here.
  9. Lumpus
    Lumpus Limp Gawd
    228
    Sep 2, 2005
    Yep. Functionality first, then clean-up after things are 100% set.
  10. Spartacus09
    Spartacus09 Gawd
    849
    Apr 21, 2018
    Then you eff something up managing everything and have to start over :p.
    Franz likes this.
  11. Franz
    Franz n00b
    2
    Jun 10, 2018
    I agree with you. :)
    France at Home is an online French Supermarket that sells French food and other products.
  12. Guarana [BAWLS]
    Guarana [BAWLS] [H]ard|Gawd
    1,761
    Oct 3, 2001
    Phanteks Enthoo Evolv ATX?
