Looking for a new case / Need Help
mikeroq
I need some help.
Im looking for a case with hard drives mounted sideways, black finish, and a clean front without a door. With plenty of room inside. I can't seem to find the right case.
Don't care about the price. Enough hard drive space where the case is big. Little bigger then a mid tower, but not bigger then a big full tower.
By side mounted hard drives, i mean like this:
Thats my current rig, but it has a different motherboard, power supply, memory, and SATA hard drives.
I know, what do I have to do, build my own case? I think cases should be more modular, where you can move things like the hard drive cage in the direction you want, ect.
I know they're out there, but I'm not familiar with all the offerings of the case manufacturers. If you give it some time somebody should be able to help you out.
Looks like you already have the CoolerMaster Centurion 534; if you like the CM's, how about the Mystique? > http://www.svc.com/rc-631-kwn1.html ... more HDD bays, and you can always remove the door?
Thats not a coolermaster, its a kingwin. I don't like the look of coolermaster cases.
Go to performance-pcs.com, and look at their Lain-Li G70 (modded) cases. I just threw out my P180 to the "Gladiator" G70, and have never looked back. Soooooo happy to be back to Lain Li!
Great case, lots of room, Able to support dual PSU (for the upcoming R600) Very light for its size (Full).
Highly recommend this case!
side mount drives and clean front panel = silverstone tj09
side mount drives, dual psu but door (i'd expect it to be removable) = lian li a10
