Tekara said:Random Stuff:
http://www.msicomputer.com/product/p_spec.asp?model=MP54GBT2&class=com[/quotte]
Alert: This Card is MSI's Proprietary Design for MS-1013, MS-1029 and MS-1036 ONLY!!
Tekara said:
This may be Doable I actualy have a Dell M50 Workstation laptop and im going to start looking for data sheets on the motherboard to find a possible place to conenct USB onboard... as this is the tresnd to do but im not looking to solder because this would void my parts and labor contract... I call and say SEND ME THIS they send it over night as told
w1retap said:Might want to look into this..
http://www.pugetsystems.com/store/item.php?cat=Accessories&id=3471&com=d41d8cd9
It doesn't mention anything about being proprietary, so do a little research and hopefully it works out.
You might have found it trying to figure out a part#/model# so ican find out the bluetooth version to make sure its not a Blue802 card if it is no go its the old spec... If not ILU and now i need to find some one that has it in stock
ill keep you guys posted on what i find..
