Looking for a MicroATX 300w supply
Splooshie
I've been looking a for a bit for a higher wattage PSU for my new MicroATX case, the system runs great until I have my 9800np installed after which the added power draw seems to cause the PSU to overheat resulting in a power down when the system is under load. The current supply is a sparkle 200w, and the only thing I can find that seems like it would be suitable is a powmax 300w matx. anyone have any experience with these supplies? At about $20 on some sites it doesnt sound like it would be too good. I have also seen 'Arrow' branded PSU's for about 40 but then those sites tend to charge 40 for the powmax aswell. Any recommendations would be helpfull.
System:
Biostar m7ncg 400
Barton 2500@3200 1.7v
2x WD cavair drives
dvd-rom
ati 9800np
4x 60mm fans
2x 80mm
Powmaxes are no good. Do not purchase them. Just don't.
Probably the best Micro ATX power supply would be the 270 W Fortron FSP270-50SNV. Fortrons typically perform better than their specs suggest. Never mind that--it'll get the job done, reliably. Another option would be the Enermax EG265S-VE, a 265 W supply.
I've never seen those units mentioned above (at least not at newegg), but here's what they do have:
200watt by Fortron
250watt by AGPB
I have no experience with either one, but I researched around newegg a while back and thought I'd throw them your way.
How do u like that biostar mobo? I am recommending it to someone based solely on it's features, and thinking about getting it for myself as well :cool:
Originally posted by Benny Blanco
...How do u like that biostar mobo? I am recommending it to someone based solely on it's features, and thinking about getting it for myself as well :cool:
Most Biostar motherboards I've seen were on PCs that people threw away. That being said, I bet they're WAY better than PC Chips motherboards.
Used to be motherboards would not become obsolete long enough to stay in yer PC through at least a couple CPU upgrades so I usually recomend ASUS or Intel. Gigabyte boards I've had have also been solid.
I know Abit is popular, but 3 out of 5 Abit BH6 MBs my friends and I had were defective in one way or another either out of the box or less than a year of use. Wierd issues where you had to use those red washers to insulate all the posts and screw that hold the MB in place or the PC wouldn't post, also on some the PS/2 keyboard ports died.
Uh, thanks... :rolleyes:
When I said "that" biostar motherboard, I was referring to the M7NCG. Do you have experience with it?
I am actually quite happy with the board so far, OC options are decent, and the it seems stable all around even if the memory bus is only rated for 333ddr it is solid up up to 420 so far (though I generally run at 400). Voltage can be set up to 2.8 on memory. 2.0 on cpu and 1.9 on the chipset all standard stuff though the memory voltage is a bit lower than on some higher end parts. From what I've gathered the onchip gpu is what holds the memory fsb back though 420 seems like a fairly common breakoff point. Other than that it had the best feature set of any M-ATX board I found, being the only one I found that used 400 cpu bus officially, and the onboard sound is much cleaner than some other nforce2 ac97 boards I've used. All the plugs are in good locations which is important in tight cases. One drawback is it does not have the mounting holes around the socket so it will limit what sinks you can attach. I've had it a month of nearly nonstop uptime so far with no issues other than the psu.
Thanks for pointing out the fortron 270 should be good enough. Aren't Fortron and sparkle usually the same thing?
Mouting holes I could care less about... but 1.9v on the chipset? :mad: (my nf7-s only goes to 1.7v!!!)
So let me get this straight, you were able to reach 420mhz fsb while using the onboard graphics? I thought it was limited to 333 automatically in that case.
If I buy that motherboard it would be 400mhz fsb tops... not looking for an EXTREME oc, just a decent one. And it seems like you have a very decent one :cool:
I've done 410ish with onboard gpu active for sure, mabey more but I dont remember if I did try higher or not... 400 is totaly stable for me with the nf2 gpu.
I just tested it again and yes 400 is totaly stable, I had to use 1.9v though.
I have the same mobo....works like a charm, no problems at all.
My $.02
Also, you did not mention what case you have....its makes a difference as to what I would suggest to you.
But I will suggest away anyway!:D
1. The only 300W mATX I could find is this one, but I have never used it so... or this one ,
2. I take it since you don't go with a regular ATX size PSU, one would not fit...correct? If so, have you tried modding one? You can cut some big chunks out of the size of a ATX PSU....just be careful :eek:
3. Depending on your case( built my own so it worked for me)you could use a server PSU either 1U or 2U....linkage follows....1U
2U
Again, this is just a thought since I don't know what case you have.
or this list here you can check out....Form Factors
I have this case. It is a microATX that turned out to have a blue LCD in the front. Ill have to mod that to red or white later. (if I can figure out how to without breaking it)
It looks like the enermax 265w might be your best bet. It claims 16a on the 12v rail. I'd ebay the other psu to try to recover some of the costs though...
