Looking for a MCR320 Template
Indignity
Please assist me if you can... This is the Swiftech 3x120 Radiator incase I word anything wrong here.
Does anybody know where I might find a .pdf(or other) file that is a template of this beast?
Obviously, I want to trace it onto a case panel to cut out an opening as well as pre-drill the screw holes.
Thanks!
Dude, you are my Case-Modding hero!!
Hell, all the help you are giving me, should I just send the parts up to you? :p
Thanks bud, I greatly appreciate your help!
Haha, really?
glad I could help.
The mounting holes might be a TAD different, but it's nothing you can't drill out as required. Infact, I know they are a bit different... I'd cut the main outline first, then do a bit of measuring and eyeballing before drilling the mounting holes.
And don't you dare send me parts... I just modded my case, I'm done modding for a good month or so :D.
Although, I AM itching to work with some acrylic and aluminum billet again :eek:
