Looking for a laptop
jimgeagea
hi everyone,
i want to buy a laptop,
i want the best one i can get at the range of 600-950$
do i go for amd or intel core duo?
Waiting for your advices :)
guys,
what do u think of that laptop:
i builted it up from dell:
Intel® Core™ Duo Proc T2300E (1.66GHz/667MHz/1 X 2MB L2 Cache)
Genuine Windows® XP Media Center 2005 Edition with re-installation CD
15.4 inch Wide Screen XGA Display with TrueLife™
2GB Shared Dual Channel DDR2 SDRAM at 533MHZ, 2 DIMM
60GB 7200rpm SATA Hard Drive
8X CD/DVD Burner (DVD+/-RW) with double-layer DVD+R write capability
256MB ATI MOBILITY™ RADEON® X1400 HyperMemory™
Integrated Sound Blaster® Audigy™ HD Software Edition
do u think i will need the 2gb or the 1gb would be enough?
jimgeagea said:
guys,
Get as much ram as you can. You didn't quote a price so I can't say if it's a good deal. You may want to check this out:
http://configure.us.dell.com/dellstore/config.aspx?CS=19&kc=11111&oc=E1505ECIRC
If you want quality, I would recommend the Lenovo (IBM) laptops:
http://www.pc.ibm.com/us/notebooks/thinkpad/r-series/rseries_byo_r60e.html
