charlesshoults
- Mar 18, 2008
I currently use a Thermaltake Mozart TX for my primary computer. At a point in time, the size of the case made sense, as I had a water cooling loop, four internal hard drives, a DVD drive and three drives in swappable bays. I've now set up a Windows Home Server system, so my daily computer now only has one hard drive and I've gone with an eSATA blu ray drive so no internal optical and my water cooling was swapped out with a Cooler Master V8. The case is now much larger than I need and the thin aluminum internal parts have developed an annoying buzzing sound.
I've looked at a number of cases, but I seem to find something wrong with all of them. My only real requirement is that it must be of adequate size to accommodate an ATX motherboard. I would also like to keep the final cost to $200 or less.
I first looked at the Silverstone Raven RV02. I like the rotated motherboard, although after reading reviews, I find two drawbacks. First, all four fans use 3-pin connectors, which normally would be a good thing, except that there are four of them, which means that in order to connect all of them to the motherboard, said motherboard would need five, fans plus CPU cooler. Second, if a DVI to D-sub adapter is needed for a monitor, which my second monitor does, the top cover does not fit.
Second, I looked at the Silverstone Kublai Series KL01-BW. This case is much more compact, yet still holds a full-size ATX board and the front-entry drive bays and quick-change front fan are nice touches, but one review showed that if a motherboard with edge-mounted SATA ports is used, the hard drive cage can interfere with the ports. And if the cage is moved higher in the case, it can interfere with the ATX power connector if said connector is along the front edge of the board.
Next, I looked at the Zalman GS1000-TT. This is an attractive case, with six front-mounted hard drives and three intake fans along the bottom of the chassis, but a review showed that of the three intake fans, one is directly below the power supply, which if the PSU does not have a side-mounted fan, becomes entirely useless. The fan toward the front is directly below the hard drives, and if in place, causes the bottom-most hard drive bay to be unusable, leaving only one good intake fan position and no air intakes anywhere else in the case. And no fan filters.
I want a good quality case, so I generally rule out anything below $70, anything with steel or aluminum thinner that 0.7mm, anything with sharp edges, anything with painted plastic, anything with bright lights or LED fans and anything with non-standard-sized fans. You can call me picky, but I call myself a realist. If a fan makes too much noise or develops a rattle, I want to be able to replace the fan with one of my choosing, rather than with the only fan available of a given size. A removable motherboard tray is nice but unnecessary, but an opening to be able to get to the CPU backplate is a definite plus. Swappable bays are good, as long as they work and side-facing hard drive cables are cool, as long as they can be point either left or right, so that cables can be hidden. Toolless designs are nice but I still want the ability to affix drives with screws. I learned that lesson with my old Antec 635 and now my Mozart TX. Oh, yeah, and I hate doors. If I have to get down on the floor to work on my computer, I want to be able to quickly and easily remove the entire panel instead of having to work around a door attached with hinges.
Any case suggestions?
