Looking for a good, compact, inexpensive camera
vsboxerboy
Hey all,
I'm looking to replace my SD1000 which was unfortunately broken the other week. I'm looking to replace it with something similar in terms of size and cost - less than 200 unless there is a good reason to go a bit over - and am wondering if there is anything better out there for the money.
I really like the CHDK alternative firmware for the long exposures, etc. - although the menus are a bit clunky at times. Obviously with this budget I'm not looking for something remotely close to top of the line and if I had to order my priorities it would be:
1. Takes SD card
2. Reasonable size
3. Picture quality
4. Optical zoom
5. Durability
Thanks for your time and opinions.
