Looking for a good 21" crt
Dr. X
I currently have a 19" (18" viewable) crt, but it's been doing some strange things lately and I think it's dying. It is pretty old, so it wouldn't surprise me. I looked at getting a 19" lcd, but I just don't think they're for me, at least not yet. I game a lot, and crts just seem to be the way to go. Anyway, I want to get a new crt, at least a 2" upgrade, so 20" viewable (I guess that would be a 21" then). Just looking for recommendations. $500 and under. Thanks.
Well theres the SAMSUNG 1100DF-Black 21" DynaFlat CRT Monitor for $450 at the Egg
Specifications:
CRT Type: 21" (20" viewable), DynaFlat CRT
Dot Pitch: 0.20mm horizontal
Max / Optimal resolution: 2048x1536 @ 75Hz / 1280x1024 @ 85Hz
Frequency / Bandwidth: fh: 30~121kHz; fv: 50~160Hz / 340MHz
Input Connectors: 15pin D-Sub, BNC x5
Features: OSD Lock/Unlock, Natural Color Software, Smart III screen treatment
Dimensions & Weight: 19.8" x 19.7" x 20" (WxHxD), 61.6 lbs
Or if you decide you dont want to spend so much theres the SAMSUNG SyncMaster 990DF-Black 19" DynaFlat CRT Monitor for $180 at the Egg
NEC 2141sb or Mitsubishi 2070sb (same monitor). You'd have to resurrect old discontinued production lines to find a more capable monitor.
True, good monitors. I have HP P1230 21" that uses same mitsu tube and electronics.. could not find mitsu or NEC here in europe, but this HP will do just fine, brand new, manufactured 2004 ...
Am I doing something wrong or the NEC going for over $1000? :eek:
EDIT: Nevermind... I looked at the prices for the monitor with a calibration kit included. Dang... I almost had a heart attack when I saw the prices on pricegrabber.com.
