So I own a coolermaster mystic, there is no side window to it. But there used to be an intake tunnel, you know, the plastic thing that tunnels cool air directly ontop of the cpu heatsink. However, it does not fit when I have my aftermarket heatsink on. I also dont want to put a fan in its place because it'll add to my system noise, and I'm getting good airflow and temps already. Putting a fan there and not turning it on was one of my ideas, but it seems...incomplete. and I'd have loose wires flopping around inside.
So my problem is, the round honeycomb design doesnt fit with the bottom square vents, and I've got 4 screw holes that are empty, and I hate empty screw holes. Does anyone have any clever ideas to mask/cover it or make it somehow sleeker?
Here is what I'm talking about.
