Looking for a cheat remote for XBMC
Jdecarol
Looking around for a cheap remote and not finding any that look good for the price. I heard something about an itouch app that would allow you to use it as a trackpad but then I would have to buy a touch.
Any news on a remote that could double as a keyboard? Or even a remote in the shape of a crackberry with a nub would be awsome.
You won't find a 'cheap' remote like that. You should throw out a price of what you are looking for.
You messed up on the title.
I'm going to be going this route: http://www.newegg.com/Product/Product.aspx?Item=N82E16880121003
Cheap, decent, good enough for me. Some reviews says it doesn't work with XBMC, but who knows. They could have fixed that by now.
I have this remote and it works for Windows Media Center. Would something like this work with a TV Tuner though? I am trying to figure out if I just need to buy the card or both the card and a remote. I will probably just do everything through Win7 MC, since a lot of people have been saying they have had good luck with it.
I don't think it'll work for a TV if that's what you meant. But a TV Tuner card in your PC, It should work just fine, I'm fairly sure that's what it was mainly made for.
$40 for a nice little wireless trackpad and keybaord
http://efo.buy-lowest.com/index.php?main_page=product_info&products_id=180
there are others who have reviewed the model and have good things to say about it
That would work perfectly. The misses is going to love the fact that I can toss the keyboard into a drawer now instead of having it under the tv. Even if it only delivers half of the distance promised it will be better than the 2 feet I get on my wireless mouse/keyboard right now.
