Looking for a cardstock compatable (laser) printer
Erebus
Hello all,
I've been looking for a printer that can handle higher DPI images (color) that can print onto cardstock. After looking around at HP, Lexmark, Xerox, and a few other websites, I've either missed printers that fit the description, or I'm not looking for the correct type of printer. Application will be similar to postcard sized projects, printed @ roughly 3000 per month. Looking to spend less than $2000 if I can. Reason I am looking at Laser instead of Ink/bubble jet is for smear resistance.
Biggest problem it looks like so far is most of them feed from a tray, and I'm thinking the cardstock I'm planning on using (about same thickness as postcards) will not feed through the rollers without bending.
Any suggestions? I would appreciate any assistance in finding this printer :)
Thank you all,
Dave
