Looking for a basic PCI-Express Motherboard
deadman_uk
My dad wants me to build him a PC which can play basic games. I figured it will be better to buy a PCI-Express motherboard and graphics card instead of AGP because its more future proof and also cheaper than AGP. Is this correct?
I am looking for a PCI-Express motherboard but have no idea what one to get. I dont understand things like SLI either.
Here are 2 that are the same price but I dont know what the difference is, can someone explain the difference between these 2 motherboards...
[size=+1]MSI K8N Neo4 Platinum nForce4 Ultra (Socket 939) PCI-Express Motherboard (MB-046-MS)[/size] [size=-1]
Ever since AMD Athlon 64 and Athlon64FX seized the crown in the 64-bit processing world; users nowadays have high expectation on AMD64 processor. The cinematic processing for virtual reality and 3D games has become one of the most-expected features by PC enthusiasts and power gamers alike. The PCI Express x16 does not only eliminate the bottleneck of AGP 8X by doubling its speed, but also by substituting the asynchronous transmitter with full-duplex architecture.
- nForce4 Ultra chipset
- USB 2.0/Firewire/dual Gb LAN
- 4x SATA2 RAID
- 7.1 Audio
- Firewall
- Supports only PCI-E VGA Cards (AGP not supported)
- ATX v2.0 compliant PSU Required for PCI-E Graphics/Motherboard
Full Specification
Price: £79.95 [size=-2] (£93.94 Including VAT at 17.5%)[/size]
[/size]
[size=+1]MSI K8N SLi Platinum nForce4 SLi (Socket 939) PCI-Express Motherboard (MB-048-MS)[/size] [size=-1]
The K8N Diamond with Nvidia SLI technology can accelerate the 3D performance by over 180% via two SLI-ready graphics cards. The Nvidia nForce4 chipset features configurable PCI Express lanes for SLI technology, and the graphics interface can be set as a single PCI Express x16 or dual PCI Express x8.
- nForce4 SLi chipset
- USB 2.0/Firewire/Gigabit LAN
- 4x SATA2 RAID
- Creative Sound Blaster Live 7.1 Onboard Dolby 24-bit Digital EX Audio
- Firewall
Full Specification
thanks
[/size]
one supports SLI... the other doesnt.
Unless you Dad is heavy into high res gaming (which he doesnt seem to be) youll never need it.
however, since having it doesnt make any diffrence. and the boards are priced the same id go with the SLI one (esp since it has the creative sound chip)
Just so you know you could get a solid board for under $100 if all you need is PCI-E.
For some reason I doubt that the SLI board is actually the Plat for that price. It is more likely the regular Neo4. The only one with the onboard Creative chip is the Plat (and the Diamond).
