Looking for a 3U Rack Case... with...
Jaxel
I've got very specific needs...
I'm looking for a nice looking 3U Rack Case... with...
  • 120mm fan mount that will fit a Corsair H60 CPU cooler
  • Space for 3 hard drives and 1 solid state drive
  • Space for a Radeon HD6950
  • Has a depth below 18 inches
It does not need space for any cd drives.
Does anyone know of any rack cases that fit these specs?
I think a found a suitable case... maybe... however I have some issues...
http://www.newegg.com/Product/Product.aspx?Item=N82E16811128065
11-128-065-Z05
As you can see, it has both a 120mm and 80mm fan in the front. But there is not enough space in the 120mm slot for a Corsair H60. If I could flip the 120mm and the 80mm fans around, and then remove the extra HDD cage, I should be able to fit the H60. Anyone have any ideas if this will work?
just delete the 5.25 frame and one of the 3.5 frames, then move the other 3..5 frame over where the 5.25 bay was.
