I have this Coolermaster Cosmos case and the included fan at 230x200x30mm is too wide for me to fit the heatsink (megahalems) that I have bought so I had to remove it.
Anyone know if a fan out there that I could obtain that would fit in this case and is only maybe 20mm in depth.... anything less than 30 I would consider. I've looked around and all the fans of this side are all 30mm in depth.
There is this Thermaltake Element T case that has a 200x200x20mm case fan that I might be able to fit into this case with a brief effort but i can't find any place that sells that.
edit: any fan around this size (230/200mm) will do. I just wish that thermaltake would sell the fans on their element cases as those would be perfect.
