Looking for a 120mm radiator
redoz
I've decided to return to water cooling after a 17 year hiatus (last time I used car parts and aquarium pumps) and it seems things have come quite far since then. Unfortunately my case, a Raijintek Styx, only fits a slim 240 and a thick 120. For the 240 I ended up with a Hardware Labs Nemesis 240 GTS X-Flow as it seemed to review well. But I can't seem to figure out what 120 to get. The GTX 120 looks nice, but for some reason it doesn't seem to be available anywhere. I was also looking at the Alphacool Nexxxos Monsta 120 (which at 80mm thick might be pushing it a bit) but I'm not sure if it's actually good or just really thick.
So I'm wondering if anyone has a recommendation? Or know where I can find some recent comparisons/reviews.
Is it safe to assume that if radiator X at 360 beats radiator Y at 360 the same will go for the 120 variants?
Edit: Ended up getting the HW labs SR2 MP.
