Looking for 3.5" card reader with multiple USB 3.0
thegreywizard
I need an internal 3.5" card reader with preferably 3-4 USB 3.0 ports
That's all I really need, nothing else fancy.
I found this one:
http://joymhc.sale.china-telecommun...front-panel-of-floppy-drive-mh-mfp-3501b.html
It's exactly what I'm looking for, although the interface on that one is PCI & I'd prefer SATA if possible - I have so many of them and the rest of my board is pretty full, especially the back ports.
So whatever kind of card reader I get, it has to plug into the board, NOT into a USB 3.0 on the back.
Any suggestions? Thanks.
I also found these three as well
This one is neat because it has a higher voltage charger for tablets/phones etc:
https://www.newegg.com/Product/Product.aspx?Item=N82E16820506001
https://www.newegg.com/Product/Product.aspx?Item=9SIA9385UV7067
https://www.newegg.com/Product/Product.aspx?Item=9SIA1JM0FD2363
They're all about the same price, seem to have all of the features I need and fair ratings (doesn't looks like I will get a 4 or 5 star rating for what I'm looking for)
And finally this one:
http://www.thermaltake.com/products-model.aspx?id=C_00001923
So I'm pretty sure I'm going with this one since it has an internal connection:
https://www.newegg.com/Product/Prod...a&cm_sp=&AID=10440897&PID=3891137&SID=rewrite
It is connected via a PCI express - so this is able to allow full USB 3.0 speeds? Or will I be bottle-necked in any way because of the PCIE interface?
The but under "Specs" & interface it says USB 2.0?
It does have a 2nd cable that seems to look like a USB 2.0 connection doesn't it? So the 6 card slots will run data through USB 2.0 & the PCIE interface allows for the USB 3.0 then?
Anyone have any thoughts?
Thanks.
In general, I would avoid anything that comes direct internationally. Quality and quality control on these can be very poor and then you're out the money since service is non-existent.
Better to find something like what you want from a reputable domestic company like Thermaltake or startech.com.
