Looking for 24" with IQ and RT
OutKlast
I'm looking for a 24" with good image quality and color saturation at a reasonable price (I know I'll have to make some concessions in IQ to get a reasonable price and usable response time). I also need something that can be used for FPS games on occasion the response time doesn't have to be super low but usable. I was looking at that DoubleSight 26" with the IPS panel but I'm doing a 3 panel setup with the center being large and the 2 outer monitor are 4:3 format 19" LCD's that I already own. Panel size wise the height a 4:3 19" and wide format 24" matches up almost perfectly. Hence why I'm looking at 24" instead of 26" but at the same time I don't want to spend so much on a 24" that for a few more dollars I could just have a 26".
I will use it for doing some photography/graphic design along with the usual web viewing/typing and some occasional gaming a few hours a week or every other week.
Any thoughts? I feel like a private investigator trying to find out what panel is used and true specs on monitors.
:(:( They don't even make IPS panels in a 24" do they? I guess I may have to suffer with a 26" screen. Oh the horror. :eek:
The only 24" IPS I'm aware of is the NEC 2490UXI. At $1100 it's significantly more expensive than the doublesight or planar 26" IPS panels.
I was also looking for a new 24" IPS and decided to go with the NEC 2490wuxi. Mind you, the difference between the 24" and 26" was a measly $60.00 or so, but I wanted the smaller dot pitch for ps/painter/maya etc..(well .27 shouldn't really be considered small given i have .255 on my current vp2030b, but you get the idea). I've heard some very good things about it, so i gave it a shot and ordered it from Dell. Can't wait 'till friday.
