austinpike
- Oct 26, 2011
Looking for a 22" IPS display with an 8-bit panel. All the 22" IPS panels I've found seem to be 6-bit+FRC. We are trying to match panel color/quality to the HP 27" IPS (zr2740w and z27i.) Have tried the NEC EA224WMi but it seems lacking in contrast. Obvious choice would be the Z22i, but I believe that is 6-bit also so I'm not sure if it would be any better than the NEC. (Will likely try that next anyway if there are no 8-bit 22" panels readily available.)
These will be distributed to a large number of users, so ideally it would be something that looks decent out of the box. The 27" HPs don't really require any tweaking to look good. Will be for business and graphics use, so speed/lag is irrelevant.
