Heya everyone. First time poster here, and I have a few questions about this NEC 24" LCD
http://www.newegg.com/Product/Product.aspx?Item=N82E16824002359&Tpk=ASLCD24WMCX
I notice that the only reviewer said that it is a TN panel. Seeing as it's $500.00, is it really worth it seeing as its a TN? Or could I find a IPS or VA panel for around that much? I really don't want to spend more than $500.00 on my panel.
I currently have a 19" TN panel, and am not bothered at all by the viewing angles. The only time I really notice it is when I recline my chair back all the way. Would I be able to notice the viewing angle more on the 24"?
Thanks
Edit:
Found this one, for less money and it's a SPVA panel. Only downside to both of these, are the built in speakers. I don't need them, and I suspect that those are just driving up the price. Could you recommend a PVA panel that wouldn't have ghosting problems in games, no built in speakers, and fits right around my budget? $450-550.00
http://www.newegg.com/Product/Product.aspx?Item=N82E16824185005
Thanks
Edit:
