I would like to find a case with a window and has a piano black finish (black with a clear coat) like the Sonata. Does anyone know if it exist or I should get a dremel and cut my Sonata?
Thanks, I went and see the Thermaltake Soprano have the window option while the Vx don't. Nice looking case. Just that it does now come with front I/O ports from what I can see on the website but I'll look for some reviews what they say.
personally I'd take the Tt Tsunami over the Tt Soprano, the front door on the Soprano is plastic, while the Tsunami is nice aluminum. Better airflow with the Tsunami also.
This is a pic of a build I did a few months back. Newegg had this slightly modified Coolermaster Wavemaster case in stock a little while ago. Pretty sure you can still find it if its what your looking for.
