Monogoat Kazer
- Apr 18, 2004
OK, I've got an Aquarius II kit that I am modifying. I have decided to mount a pump and reservior in a 5.25 bay. I am using the case from an old cd-rom to contain it, using the backup reservior from my kit as the reservior, but now I need a pump that will fit inside. One dimension of the pump has to be 1.5" or less. Preferably a little lass so that I can add some kind of material to dampin vibrations. Does anyone know where I can find one?
