Look at this
Kenny
[/IMG] 9800 pro dust building up, does any 1 know a safe way to clean.
blast it with compressed air? (might be easier if you take it out of the case of course)
PC Chips????
..I just use my air compressor on my comps each month...works good.
Also note the 1 stick of RAM, budget looking PCI slots covers (on the case,) stock AMD CPU HSF and colored LED fan.
My guess is that he bought it off someone else for a low price.
major upgrade needed do u know a good mother board i can bye. hzink fine cools ok for what i need.
I would makesure everything Is plugged in and the lick the PCB clean.
This not only cleans your card, but has two other benefits:
1. Extra Nutritional Value in your Diet
2. Saliva acts to cool your card
gravity...
dust accumulates easier on your video card thats sitting horizonally than your motherboard sitting vertically. since your video card is the top most card it should have the most but there should still be some on the other cards below it. do you have pets or something old carpeting?
Use a brand new painting brush with nice fine horse hair and clean it along with some compressed air. Best way to get it done, compressed air alone does not do it.
