infinity4life
- Dec 23, 2005
I had my friend build my latest setup (I'm just too lazy these days ^_^ ).......only problem is that he did the wiring job from hell..........probably a stupid question, but is it possible to get longer than stock wires (e.g., longer than stock SATA hd wires, vga-slot cooler fan wires, etc....) so they can be yanked to the side and zip-tied off? Right now they're stretched to the limit, all over the case, so there's no way I can zip-tie them off to make it more accesible
to give you an idea - it took me almost 1 1/2hrs to remove my SLI'd video cards because of the amount of wiring mess I had to contend with :/
