Long term problems from not plugging in 12v
I wasn't aware they'd even boot without it connected... what the hell?
Yeah, I didn't think it would boot, I know when I first set up mine, I forgot the 12v plug, and it wouldn't boot.
id say check em all over, if the guy who put em together didnt plug in the 12v, who knows what else he/she didnt do...
Yeah I was suprised they booted as well. They're Athlon 64 boxes, worst experience every until I plugged in all the 12v. Still no ideas on long term problems? So far I've found bad HDD, bad RAM, I'm just wondering what/if any any damages to the mobo's would be?
I guess a lorng-term problem is that the motherboard may be damaged from carrying too much on its 3.3V (?) rail (I think thats one of the rails the CPU uses also, correct me if I'm wrong cause I'm sure I am :) ). I mean, think about it... if it was able to boot, AND function, then it has to draw the power from somewhere, right? And if the motherboard's circuits are not capable of carrying the sort of current needed by the CPU, then they could be (quite severely) damaged. And if they are damaged, then the power flowing through the motherboard to other components could be insufficient, not constant, etc. so causing some instability.
Does this sound plausible? It may just have sounded better in my head then it did when it came out... lol. But I think that could definately damage the motherboard.
