Later this month I am leaving on vacation I am looking at borrowing wifi from a friend as I usually do, however I am looking for very long range USB wifi adapters or PC Card.
All the top notch PC cards I have looked at (Senao, SMC) are still of course the B-standard, although that is still far better than dial-up (not to mention cheaper!). Intially I only considered these cards as they had the 200mW spec/23dbi and looking at wifi sites, many said that USB simply did not have enough power to provide similar results.
However, then I discovered the Hawking HWU54D usb 2 wifi adapter, which is cheaper than a Senao+antennas and has equivelant power specs it seems. I would only get B speeds from this anyway as my laptop only has usb1.1, however it is 1/2 the price and more versatile.
Any advice?
Any advice?
