I am attempting to set up a small thermal receipt printer about 500ft away from a laptop. I've tossed around a few ideas:
1.) Laptop -> Wireless Router -> Wireless Print Server -> Printer
2.) Laptop -> Switch -> 300ft Cat5 Cable -> Repeater -> 200ft Cat5 Cable -> Print Server -> Printer
3.) Laptop -> Switch -> PoE Injector -> 300ft Cat5 Cable -> PoE Repeater -> 200ft Cat5 -> PoE Power Adapter -> Print Server -> Printer
Option 1 is simple, less equipment, but I'm not sure how reliable the connection would be (I have scars from wireless installs). Plus I would need to provide a power source at the end (loong extension cord).
Option 2 would be simple, but I would have to provide power at the repeater as well as at the printer and I'm not sure if, even with the repeater, I would have consistent data transfer.
Option 3 is the coolest in my opinion, but I have never worked with PoE and consequently am a bit nervous about building a system around it. I thought something like this http://www.pcconnection.com/ProductDetail?Sku=5487461 could possibly power the print server and printer at the cable end - eliminating the need for a long extension cord.
What would you networking gurus recommend? Note that this install has to be setup and then taken down in 1 day for events. Durability is a concern. Cables would lay on top of asphalt and it's possible that they would be stepped on by un-aware walkers.
Also, fyi, the application is at an autocross. We have a timing trailer and would like to station a thermal printer at the finish line to run off timing slips for each person as they finish. The finish is typically no more than 500ft away.
Thanks for any advice,
BFarm
BFarm
